entirelynutz2
Sep 18, 2023Aspirant
Logging not working after firmware update
I have a Nighthawk RAX120v2 Wifi router.I recently updated the firmware to V1.2.8.40. ever since then the only entries I see in the log file are DHCP IP: entries, and supervisor logins. I'm not seein...
microchip8
Sep 18, 2023Master
Logging is not configurable. Nothing you can do about it as there are no options.
- entirelynutz2Sep 18, 2023Aspirant
It reported all kinds of traffic before the firmware update.
- KitsapSep 18, 2023Master
entirelynutz2 wrote:It reported all kinds of traffic before the firmware update.
Firmware updates very often make changes to the router log feature. I do consider the enable/disable selection of events to be a configuration. With different routers and different firmware updates, some of the events have become non functional. How many versions of firmware did you jump from old to new?
Anytime you perform a firmware update and there are issues after the update, the first course of action should be a firmware default reset. I know it is a PIA, but it has proven to be the most effective and efficient course of action to correct problems with a router.
