WiFiNoob
Jul 16, 2022Aspirant
Logging Options for R6700v2
I’m using an R6700v2 with Router Firmware Version V1.2.0.92_1.0.1 Yesterday I turned on email notification at: Advanced → Security → E-mail Now I get logs emailed to me every few hours. Appa...
Jul 24, 2022Guru - Experienced User
Unfortunately WYSIWYG kind of logging for emails and logs.
The log section is kind of descriptive for each time If you don't need the ones listed, uncheck them. I only new a few when i have email logs enabled. All other other use, like access to blocked or allowed sites, VPN and wireless access are disabled.
- WiFiNoobJul 24, 2022Aspirant
Thank you for replying.
I’m setting the logging options at:
Advanced → Administration → Logs
To stop logging ALL accesses, apparently BOTH these options must NOT be checked:
- Attempted access to allowed sites
- Attempted access to blocked sites and services
If EITHER of them is checked then ALL “[Access Control]” entries such as the following example will appear in the log:
[Access Control] Device Lia_iPad_Pri with MAC address 4E:C4:22:D2:F5:A9 is allowed to Sunday, July 24,2022 18:29:13
What I want to log are only accesses by previously unknown MAC Addresses.
Is there anyway to log just new or unlabeled MAC Addresses?
Thank you for your help.
