WiFiNoob
Jul 16, 2022Aspirant
Logging Options for R6700v2
I’m using an R6700v2 with Router Firmware Version V1.2.0.92_1.0.1 Yesterday I turned on email notification at: Advanced → Security → E-mail Now I get logs emailed to me every few hours. Appa...
Jul 24, 2022Guru - Experienced User
Unfortunately WYSIWYG kind of logging for emails and logs.
The log section is kind of descriptive for each time If you don't need the ones listed, uncheck them. I only new a few when i have email logs enabled. All other other use, like access to blocked or allowed sites, VPN and wireless access are disabled.
WiFiNoob
Jul 24, 2022Aspirant
Thank you for replying.
I’m setting the logging options at:
Advanced → Administration → Logs
To stop logging ALL accesses, apparently BOTH these options must NOT be checked:
- Attempted access to allowed sites
- Attempted access to blocked sites and services
If EITHER of them is checked then ALL “[Access Control]” entries such as the following example will appear in the log:
[Access Control] Device Lia_iPad_Pri with MAC address 4E:C4:22:D2:F5:A9 is allowed to Sunday, July 24,2022 18:29:13
What I want to log are only accesses by previously unknown MAC Addresses.
Is there anyway to log just new or unlabeled MAC Addresses?
Thank you for your help.
