Silvertop007
Jun 26, 2022Aspirant
Login on night hawk ac1900
Cannot access my router login page from iPad. It takes me too netgrear web site. any answers?
- Jun 30, 2022
I used safari to log in to router login page. Instead of using www.router login.net .
I used http://192.168.1.1 it worked great! Thanks to everyone that tried to help.
Jun 26, 2022Guru - Experienced User
AC1900 is a wifi combined speed. Not a model #. What model router do you have?
Is this thru a web browser on the pad or using the Nighthawk app?
Silvertop007
Jun 30, 2022Aspirant
- michaelkenwardJun 30, 2022Guru - Experienced User
Interesting. That can be a sign that you have something else on your network that messes around with turning typed URLs into meaningful IP addresses. That something can be a modem/router in front of the router.
We failed to ask you for details of your modem/gateway. Thanks for the reminder to check that.
- Silvertop007Jul 01, 2022Aspirant
I have a modem provided by my ISP which is spectrum.
- michaelkenwardJul 01, 2022Guru - Experienced User
And that modem is? Your ISP must have supplied many different models over the years. They won't all be the same. The devil is in the details.
