_Rajendra_
Jul 14, 2016Tutor
Login Page Dead with Chrome - Edge works
If I try to log in to 192.168.1.1 with Chrome, I get 192.168.1.1 refused to connect. However, if I reboot the router and use Edge, I'm able to log in. If I try Chrome again, I get the above e...
- Jul 27, 2016
I finally figured out the problem. Turns out I had a HotSpot Shield add-on on Chrome. When I first connect to the router using Chrome, the add-on probably does something causing the router to block all traffic to 192.168.1.1. I uninstalled the add-on, rebooted the router, and now all is fine.
_Rajendra_
Jul 15, 2016Tutor
I don't think this is the problem. The first time I use Chrome, I can no longer access the login page from any device or any browser. So it looks like the router is refusing all connections to 192.168.1.1.
JamesGL
Jul 19, 2016NETGEAR Employee Retired
Hi _Rajendra_,
Try resetting the router to factory default. Check for the firmware and update it.
- _Rajendra_Jul 20, 2016Tutor
It has the latest firmware. I don't want to do a factory reset and lose all of my configuration settings. There has to be another way to do this.
- JamesGLJul 25, 2016NETGEAR Employee Retired
7Hi _Rajendra_,
Try to do back up on the settings on the device then reset. I do not have issues with my R7000 when accessing the UI.
- _Rajendra_Jul 27, 2016Tutor
