_Rajendra_
Jul 14, 2016Tutor
Login Page Dead with Chrome - Edge works
If I try to log in to 192.168.1.1 with Chrome, I get 192.168.1.1 refused to connect. However, if I reboot the router and use Edge, I'm able to log in. If I try Chrome again, I get the above e...
- Jul 27, 2016
I finally figured out the problem. Turns out I had a HotSpot Shield add-on on Chrome. When I first connect to the router using Chrome, the add-on probably does something causing the router to block all traffic to 192.168.1.1. I uninstalled the add-on, rebooted the router, and now all is fine.
JamesGL
Jul 20, 2016NETGEAR Employee Retired
Hi _Rajendra_,
Try resetting the router to factory default. Check for the firmware and update it.
_Rajendra_
Jul 20, 2016Tutor
It has the latest firmware. I don't want to do a factory reset and lose all of my configuration settings. There has to be another way to do this.
- JamesGLJul 26, 2016NETGEAR Employee Retired
7Hi _Rajendra_,
Try to do back up on the settings on the device then reset. I do not have issues with my R7000 when accessing the UI.
- _Rajendra_Jul 27, 2016Tutor
- JamesGLJul 28, 2016NETGEAR Employee Retired
Hi _Rajendra_,
Good to know it works now.
