abenn89's avatar
abenn89
Follower
Feb 09, 2023
Login problem
Nighthawk X6 AC3200 won't accept default password. Setting up router but I can't login using admin/password
  • plemans's avatar
    Is this a new install?
    Was it a pre-owned product?
    like Kitsap says, a factory reset might be a good place to start to get back to the defaults.
  • michaelkenward's avatar
    michaelkenward
    What are you doing and where does it go wrong?
    Setting up router how? (There are several ways of doing that.) Wired? App? Browser?
    Login to what? How?
    What messages do you see when you try?
