thompsondc
May 15, 2023Tutor
Login when in Access Point mode
I've set my R7800 into access point mode, as I have a Mikrotik RB4011+ performing DHCP. I can connect to my Nighthawk via the android app, but not via IP over the LAN. The only thing I want to do i...
- May 16, 2023
Your call.
The alternative is, of course, to leave the R7800 to manage its IP address and to tell the Mikrotik router to keeps its hands off.
Just because it used to rule the roost does not mean that it has to do that for ever.
thompsondc
May 15, 2023Tutor
Yes, I mean via web browser. Firmware is v1.0.2.92.
May 15, 2023Guru - Experienced User
How is it now working?
Recommend manually checking for FW updates on the NG download page or here in the forums. Sometimes NG will not post new FW to the auto update servers.
