thompsondc
May 15, 2023Tutor
Login when in Access Point mode
I've set my R7800 into access point mode, as I have a Mikrotik RB4011+ performing DHCP. I can connect to my Nighthawk via the android app, but not via IP over the LAN. The only thing I want to do i...
- May 16, 2023
Your call.
The alternative is, of course, to leave the R7800 to manage its IP address and to tell the Mikrotik router to keeps its hands off.
Just because it used to rule the roost does not mean that it has to do that for ever.
michaelkenward
May 15, 2023Guru - Experienced User
plemans wrote:
Are you using the IP address the Mikrotik is assigning to it?
That's the way to do it.
There are various ways of finding the IP address. As plemans hints, you can look at the router's list of attached devices.
Another way is to use the Netgear genie for your operating system.
genie | Product | Support | NETGEAR
The good thing there is that it shows a map of the network and the AP may well show up as a clickable link. A neat tool if you want to do this regularly.
Another way to make life easy is to fic the IP address on the AP so that you can always go to that to get at the browser graphical user interface (GUI).
thompsondc
May 15, 2023Tutor
After doing a deepdive, I've figured it out. I have a DHCP reservation for the R7800 on the Mikrotik, which I was seeing in RouterOS's DHCP Server > Leases screen; however the R7800 is picking up a different IP (of it's choosing), much higher in number (and therefore further down the page...
Apologies for ultimately not scrolling down to locate the correct IP. I used the correct one, and I'm good.
Any ideas on how to force the R7800 to take the IP reserved for it?
- michaelkenwardMay 15, 2023Guru - Experienced User
Look in the settings.
- Settings
- Advanced setup
- Router / AP/ Bridge Mode
- AP Mode
- Use fixed IP Address (not recommended)
Take it away....
- thompsondcMay 15, 2023Tutor
Thanks. I did that. Although it says that method is NOT recommended:
- michaelkenwardMay 16, 2023Guru - Experienced User
Your call.
