LassoTool
Mar 18, 2023Aspirant
Logs incomplete
Model: R6700v2 It seems each individual log entry is cut off, resulting in an incomplete set of data. Example of incomplete data line: “[Access Control] Device IMAC with MAC address xx:xx:xx:...
Kitsap
Mar 20, 2023Master
In your router configuration, you can go to Advanced -> Security -> Email and set up to allow you router to send you an e-mail. Then in the Advanced -> Administration -> Logs section you have the option to Send Log to yourself via e-mail. The information and lines may be more complete than what you are seeing on the screen.
Another option is to select all of the text in the log window, copy it to the clipboard, and then paste it into a blank page in a word processing program.
- LassoToolMar 20, 2023AspirantThanks for the suggestion, I had this same thought. Unfortunately, the emailed log is sent more or less as plaintext and does not show any additional information. Everything is truncated same as before.
