Henry147843
Mar 12, 2023Follower
Look fore router
I know nothing about them I am looking for a router that can take 20 upload speed and 15 devices at a decent price don’t no what to look for
michaelkenward
Mar 13, 2023Guru - Experienced User
It might help to tell people what the modem/gateway/ONT is that will connect your router to the Internet. Your Internet service provider may also have advice on compatible routers.
Then try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
