Huss79
Oct 18, 2019Aspirant
Looking for a gbit wifi router nbn compatible ddwrt compatible
Hi I have HFC nbn I’m looking for a decent wifi router that’s compatible with ddwrt firmware so that I can install NordVPN my price range is up to $220 I would prefer 5Ghz with atleast 4 gbit Ethernet...
- Oct 26, 2019I ended up going with Asusit doesn't need 3rd party software works straight out of the box.. Ty
Oct 18, 2019Guru - Experienced User
I'd probably look at the R7800. in that price range, has the feautres you want, has 3rd party software (which these forums can't/won't help you with).
Plus its been a fairly solid/reliable/good performing router imo.
