Huss79
Oct 18, 2019Aspirant
Looking for a gbit wifi router nbn compatible ddwrt compatible
Hi I have HFC nbn I’m looking for a decent wifi router that’s compatible with ddwrt firmware so that I can install NordVPN my price range is up to $220 I would prefer 5Ghz with atleast 4 gbit Ethernet...
- Oct 26, 2019I ended up going with Asusit doesn't need 3rd party software works straight out of the box.. Ty
Huss79
will it be able to be flashed with ddwrt i know i wont get the help here which is fine i just want to make sure i can use that firmware on it before i go out and buy it
Oct 18, 2019Guru - Experienced User
Not to be evil but you have to do a little research on your own for 3rd party support.
https://dd-wrt.com/support/router-database/?model=R7800_v1
- michaelkenwardOct 19, 2019Guru - Experienced User
Another R7800 fan boy here.
plemans wrote:
Not to be evil but you have to do a little research on your own for 3rd party support.It isn't evil to tell someone that it is a bit silly asking for advice here about alternative firmware. This is a Netgear community. While some people here are familiar with alternatives, genuine experts may be rare. And Netgear probably isn't keen to encourage such use. (It would break any warranty.)
