MizterPolo
Aug 03, 2018Guide
Looking for an old firmware
Looking for firmware 1.0.4.12_10.1.46, read a few place reverting to this firmware will help my issue of " turn off scheduling". As of now if i check the box and appy the settings don't stick.
Go to the SUPPORT link on the TOP of the page, enter R8000 and click on the line below the entry box then hit enter. Next select DOWNLOADS, and at the bottom of the list is Previous Version. Select that and there they are... d/l, unzip, update pointing to where you placed the .CHK file and say OK to the prompt that you are loading and older version.
- IrvSpMaster
THANKS
