iakst2
Mar 09, 2021Follower
looking for internet extender for Nighthawk® DOCSIS® 3.1 6Gbps Two-in-one Cable Modem + WiFi 6 Route
Hello, I have a Nighthawk® DOCSIS® 3.1 6Gbps Two-in-one Cable Modem + WiFi 6 Router and am looking for internet extender to work with this modem-router. It is located on the second floor of my...
michaelkenward
Mar 10, 2021Guru - Experienced User
Anything designed for the purpose should work.
Start here and feed in your needs:
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
iakst2 wrote:
Would this extender work:
Dual-band WiFi 6 Mesh Extender, 1.8Gbps, Wall-plug, Internal Antenna
It should, but that is a description, not a Netgear model number.
