Greggooo's avatar
Greggooo
Looking for Orbi outdoor satellite power
Hi! Trying to find the watts or amps used by the RBS50Y Orbi outdoor satellite. Anybody know?
  • plemans's avatar
    Its output is a 12v 2.5amp output.
    so at max it uses 30 watts. That'd be at max. I doubt it uses that on average.
    • Greggooo's avatar
      Greggooo
      Great! So at 30 watts, it's around .25 amps draw from the outlet. I saw the regular satelite extender listsed at around 34 watts, but didn't know if this was the same.
      Thank you.
      • plemans's avatar
        It might be around that roughly at the wall because you're going to have a little loss due to efficiency at the power brick. I was just going with what its output is. So that input of 34watt might be about right. But I doubt it'll use that much. Most power supplies rarely use their peak output.
