axltl23
May 30, 2023Tutor
Looking Into Buying a New Router
I have a problem with my 5g wifi going out every day and I can't seem to fix it even with the help of people from the community. So I'm looking for a new router to buy in the 100$-200$ range that has...
May 30, 2023Guru - Experienced User
I've found some good used/referbed routers on Amazon for cheap that work well.
R8000, MK63 MESH. XR1000. All under $200
Might look at a RAX50 series for newer generation class router.
