sniemeier
Jan 04, 2021Aspirant
Looking to Upgrade Wi-Fi Router
I have a NETGEAR CM500-100NAR DOCSIS 3.0 Cable Modem with 16x4 Max Download speeds of 680Mbps. Its hooked up to a Negear R6400 Wireless Router. I have Comcast Performance Plus Internet (up to 60 m...
sniemeier
Do you think my Netgear R6400 Router is powerful enough if that is all I have for the house? If I purchased a stronger range extender, would that be wise? What brand/model range extender would you recommend?
Are the new Wi-Fi 6 routers out like the AX4300 that Costco carries be a better router for my house size?
I just don't want to buy something that won't improve my speed throughout the house.
Thanks again for your replies!
Jan 04, 2021Guru - Experienced User
if you're only getting/paying for 60mbps from the isp, I'd look more at the triband orbi systems.
I'd look for one with 2 satellites like the rbk43/53
