LitoGeorge
Nov 30, 2018Aspirant
Loose internal antenna connector R7000
My Nighthawk in otherwise great condition has its left hand (looking at it from the rear) internal connector loose.
I am able to hold it and nothing else rattles inside when giving it a shake....
- Dec 02, 2018
Solder is the best way to go IMHO. That is what I wold do. This is just ground pads so no real connection to worry about.
myersw
Dec 01, 2018Master
When you say internal connector loose are you saying the wire from the antenna to the circuit board is loose? If so only way to fix is to pop open the case, which will VOID the warrenty if you still have one, and if you still have warrently call Netgear for RMA.
Case is easy to open, just flip it over and start taking out screws. There will be one under a label that has to come out. Their way of telling if you opened the cover. There are some guides about using a serial connection to recover the r7000, but I think all of them assume you can turn it over figure out the screws.
LitoGeorge
Dec 02, 2018Aspirant
- myerswDec 02, 2018Master
