RTaylor
Dec 21, 2020Aspirant
Looses configuration after power outage - Router Resets
Every time I loose power the router resets. Add to that, I can't open a ticket as their system seem to indicate I have no registered products. Right, that's not what my product registration conf...
Dec 21, 2020Guru - Experienced User
What firmware version are you on?
- RTaylorDec 21, 2020Aspirant
The router is running Firmware Version - V1.4.1.64_1.3.25
- plemansDec 21, 2020Guru - Experienced User
You can play around with firmware versions but AVOID version 1.4.1.50. For some reason it locks the firmware to that version if you install it.
What I'd try doing? Reinstall the current version over a hardwired connection. Do a factory reset and a clean install (don't use a backup configuration). Try this first. If it doesn't work, then I'd try the .62 version. Again, DO NOT install the .50 version.
- labattDec 21, 2020Mentor
Might I also add that if you are losing power frequenty that you invest in a PSU. Then when power is disrupted the PSU would keep the router up. Then you will not have the other issues.
