Dseg
Oct 25, 2020Follower
Losing connection to 5G network
Nighthawk RAX40 5G network not working Didnt realize when I purchased this device in March 2020, I wouldn't get Netgear support within the same year. Presently my devices are losing connection to 5G ...
- Oct 25, 2020
What firmware version are you on?
Have you tried a factory reset and then reinstall (not from backup)? The RAX devices were pretty new and have reponded favorably to factory resets.
rinthos
Oct 25, 2020Luminary
This will sound weird but try the following:
Fresh reboot the router. Then...
1) Disable QoS if on.
2) Disable IPv6 if configured.
3) From Advanced Wireless disable: MU-MIMO
See if that helps. If not, sadly reload firmware, factory reset thr router, reconfigure, and see if that fixes it.
Also curious question..do you have Netvear Armor enabled?
