dcplumley
Feb 24, 2022Tutor
losing internet daily again
after lastest update in firmware the router has to reset daily. went back to V1.0.4.120_10.0.91 and now the issue still exists.... any thoughts? turning on ip6v only last a month,,,
Feb 25, 2022Guru - Experienced User
Happens with both wired and wireless devices?
- dcplumleyFeb 25, 2022TutorNetgear cm1000.
Nighthawk always says connect.- FURRYe38Feb 25, 2022Guru - Experienced User
Does the Front Internet LED show any indications of something happening when you see this? Like maybe AMBER color seen on the Internet LED on the router or modem?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- dcplumleyFeb 25, 2022Tutor
had done all of that before.
No changes on the led. they think everything is fine.
Do you think the modem is the issue?
When I reset the nighthawk the iternet comes back. Don't typically reset the modem.
