dcplumley
Feb 24, 2022Tutor
losing internet daily again
after lastest update in firmware the router has to reset daily. went back to V1.0.4.120_10.0.91 and now the issue still exists.... any thoughts? turning on ip6v only last a month,,,
dcplumley
Feb 25, 2022Tutor
Netgear cm1000.
Nighthawk always says connect.
Feb 25, 2022Guru - Experienced User
Does the Front Internet LED show any indications of something happening when you see this? Like maybe AMBER color seen on the Internet LED on the router or modem?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- dcplumleyFeb 25, 2022Tutor
had done all of that before.
No changes on the led. they think everything is fine.
Do you think the modem is the issue?
When I reset the nighthawk the iternet comes back. Don't typically reset the modem.
- FURRYe38Feb 25, 2022Guru - Experienced User
Possible.
I'd power OFF the modem for 1 minute then back ON. Reset it as well and let it come to ready.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html- dcplumleyFeb 25, 2022Tutor
Have been here for two years and this problem just started. The line was newly installed two years ago.
And fully checked. Could possible have them recheck but seem a bite strange and restting the wireless router fixes the problem and not having to reset both items.
Even doing a reset in the menu under wirelss corrects the issue....
