sid01's avatar
sid01
Initiate
Aug 01, 2021
Lost 5Ghz Networks
Hi all. The above model running is running firmware V1.0.4.74_10.1.80   Sometime in the last few days or weeks we have lost our two 5Ghz wifi bands i.e. we cannot see them in available networks. Th...
  • plemans's avatar
    Aug 01, 2021
    Are you using smart connect?
    Smart connect combines all 3 bands into 1 band. And unless you're using more than a standard wifi scanner, it won't show them as seperate.
