garyjc
Aug 17, 2022Aspirant
Lost access to Buffalo Linkstation NAS after firmware update and reboot of X10 R9000
I'm using Windows 10 pro and have an X10 R9000 Router that's been working great since 2019. Two days ago I installed version V1.0.5.42 firmware update and rebooted the router. Since then I can't acc...
michaelkenward
Aug 18, 2022Guru - Experienced User
garyjc wrote:
Since I had no problems with accessing the NAS prior to firmware update and reboot I have to assume that it changed something.
Windows is also good at throwing out changes that break things. Every time it updates I have to mend stuff.
Having said that, my Linkstation has survived many a Windows update. Now on Windows 11.
I'd start with what Kitsap suggests.
To check if it is firmware, you could roll back to the one before your NAS died.
garyjc
Aug 20, 2022Aspirant
Not sure how to safely roll back to previous firmware. I've always logged in to router from my computer to update, but I don't see an option in router settings to accomplish that. I don't want to do something wrong that might brick my router. I downloaded the previous version from the Netgear website but I'm not 100% sure if it's the one that was in use prior to updating to the latest ver. It might be possible that I missed an update. Is it safe just to run the downloaded update, or do I need to perform any other steps first?
- michaelkenwardAug 20, 2022Guru - Experienced User
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Experienced users prefer that to the automated process.
It means that they don't rely in a possibly flaky Internet connection to make it happen.
Whatever you do, make a backup copy of your current configuration.
- KitsapAug 20, 2022Master
I am not trying to discourage you from learning how to roll back your router firmware and do so properly (i.e. with a web browser and a computer connected via Ethernet to your router). But, rolling back your router firmware will do nothing to correct or restore your windows settings so you can access your NAS files.
- garyjcAug 22, 2022Aspirant
You were right about rolling back the firmware, it didn't solve the problem so I updated to the newest version again. I've tried everything the internet offered for a fix and still cant access my NAS. I can successfully ping the router and I tried accessing it using it's ip address under Map Network Drive but it returns a Network Error "Windows cannot access". Clicking on Diagnose shows the message Details: "The device or resource (LS-WTGL7AF) is not set up to accept connections on port "The Fire and printer sharing (SMB)" I've triple checked and ALL the SMB boxes are checked. Any other suggestions?
