garyjc
Aug 17, 2022Aspirant
Lost access to Buffalo Linkstation NAS after firmware update and reboot of X10 R9000
I'm using Windows 10 pro and have an X10 R9000 Router that's been working great since 2019. Two days ago I installed version V1.0.5.42 firmware update and rebooted the router. Since then I can't acc...
Kitsap
Aug 20, 2022Master
I am not trying to discourage you from learning how to roll back your router firmware and do so properly (i.e. with a web browser and a computer connected via Ethernet to your router). But, rolling back your router firmware will do nothing to correct or restore your windows settings so you can access your NAS files.
garyjc
Aug 22, 2022Aspirant
You were right about rolling back the firmware, it didn't solve the problem so I updated to the newest version again. I've tried everything the internet offered for a fix and still cant access my NAS. I can successfully ping the router and I tried accessing it using it's ip address under Map Network Drive but it returns a Network Error "Windows cannot access". Clicking on Diagnose shows the message Details: "The device or resource (LS-WTGL7AF) is not set up to accept connections on port "The Fire and printer sharing (SMB)" I've triple checked and ALL the SMB boxes are checked. Any other suggestions?
- KitsapAug 22, 2022Master
garyjc wrote:You were right about rolling back the firmware, it didn't solve the problem so I updated to the newest version again. I've tried everything the internet offered for a fix and still cant access my NAS. I can successfully ping the router and I tried accessing it using it's ip address under Map Network Drive but it returns a Network Error "Windows cannot access". Clicking on Diagnose shows the message Details: "The device or resource (LS-WTGL7AF) is not set up to accept connections on port "The Fire and printer sharing (SMB)" I've triple checked and ALL the SMB boxes are checked. Any other suggestions?
I do not think you meant "router" above. Most likely NAS box.
So far everything is pointing to a configuration problem with your NAS box. Have you checked for firmware updates for your NAS?
- garyjcAug 23, 2022Aspirant
Buffalo Model Number: LS-WTGL/R1-V3 LinkStation Pro Duo
I may have forgotten to mention that it is no longer visible to laptops on the network. One is Windows 10 the other is Windows 7. Both are wifi and had access previously.
You're correct, Router should have been NAS. The only firmware update from Buffalo for my model is Version is V3 3.09 dated 1/23/2009. The version shown when logging into the NAS is 3.10.
- michaelkenwardAug 23, 2022Guru - Experienced User
Is that the NAS Navigator?
On SMB, this is how I am set up.
My LinkStation LSD210D works fine.
