garyjc
Aug 17, 2022Aspirant
Lost access to Buffalo Linkstation NAS after firmware update and reboot of X10 R9000
I'm using Windows 10 pro and have an X10 R9000 Router that's been working great since 2019. Two days ago I installed version V1.0.5.42 firmware update and rebooted the router. Since then I can't acc...
garyjc
Aug 23, 2022Aspirant
Buffalo Model Number: LS-WTGL/R1-V3 LinkStation Pro Duo
I may have forgotten to mention that it is no longer visible to laptops on the network. One is Windows 10 the other is Windows 7. Both are wifi and had access previously.
Kitsap
Aug 23, 2022Master
There are help forums on the Buffalo Tech web site. Here is one link:
https://forums.buffalotech.com/index.php?PHPSESSID=efde1c9e74d60821d92fdb993c3bcbac&board=7.0
You can do your own review of the threads. There were recent updates to Windows that impacted devices that use SMB1 for network communication. I recall Windows disabled SMB1 and it is possible to re-enable it in Windows settings.
Put Windows SMB1 in your web browser search engine. Lots of information available. You just have to sort through it. Some may be scams and recommend you don't download and install "Help Site" software. Steer toward links to Microsoft articles.
https://duckduckgo.com/?t=ffsb&q=windows+smb1&atb=v167-1&ia=web
