garyjc
Aug 17, 2022Aspirant
Lost access to Buffalo Linkstation NAS after firmware update and reboot of X10 R9000
I'm using Windows 10 pro and have an X10 R9000 Router that's been working great since 2019. Two days ago I installed version V1.0.5.42 firmware update and rebooted the router. Since then I can't acc...
Kitsap
Aug 22, 2022Master
garyjc wrote:You were right about rolling back the firmware, it didn't solve the problem so I updated to the newest version again. I've tried everything the internet offered for a fix and still cant access my NAS. I can successfully ping the router and I tried accessing it using it's ip address under Map Network Drive but it returns a Network Error "Windows cannot access". Clicking on Diagnose shows the message Details: "The device or resource (LS-WTGL7AF) is not set up to accept connections on port "The Fire and printer sharing (SMB)" I've triple checked and ALL the SMB boxes are checked. Any other suggestions?
I do not think you meant "router" above. Most likely NAS box.
So far everything is pointing to a configuration problem with your NAS box. Have you checked for firmware updates for your NAS?
garyjc
Aug 23, 2022Aspirant
You're correct, Router should have been NAS. The only firmware update from Buffalo for my model is Version is V3 3.09 dated 1/23/2009. The version shown when logging into the NAS is 3.10.
