garyjc
Aug 17, 2022Aspirant
Lost access to Buffalo Linkstation NAS after firmware update and reboot of X10 R9000
I'm using Windows 10 pro and have an X10 R9000 Router that's been working great since 2019. Two days ago I installed version V1.0.5.42 firmware update and rebooted the router. Since then I can't acc...
Kitsap
Aug 23, 2022Master
There are help forums on the Buffalo Tech web site. Here is one link:
https://forums.buffalotech.com/index.php?PHPSESSID=efde1c9e74d60821d92fdb993c3bcbac&board=7.0
You can do your own review of the threads. There were recent updates to Windows that impacted devices that use SMB1 for network communication. I recall Windows disabled SMB1 and it is possible to re-enable it in Windows settings.
Put Windows SMB1 in your web browser search engine. Lots of information available. You just have to sort through it. Some may be scams and recommend you don't download and install "Help Site" software. Steer toward links to Microsoft articles.
https://duckduckgo.com/?t=ffsb&q=windows+smb1&atb=v167-1&ia=web
michaelkenward
Aug 23, 2022Guru - Experienced User
That was a long time ago.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
That's a ReadySHARE thing rather than NAS, but it might be worth reviewing.
