nUUK25
Feb 25, 2023Tutor
Lost cable connections (LAN 1-4) does not work (Wireless works) on Nighthawk X4s AC2600 (R7800)
Hi There, All my cable connections (LAN 1-4) from the router does not work suddenly when it is connected to switch and PC. I have not touched the router beforehand. Wireless connection to PC and sm...
- Feb 25, 2023
Any clues from the LAN LEDs?
Have you reset the thing?
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems. It is also the first thing that Netgear support will recommend.
michaelkenward
Feb 25, 2023Guru - Experienced User
nUUK25
Feb 25, 2023Tutor
Thanks Michael,
It came back after some more router booting - so maybe firmware update was a good thing.
Regards Lars
