required_alias
Jun 16, 2022Guide
Lost connection to 50hz network
Had a similar issue quite a while back, but it 'healed' itself. Unsure whether to start a new discussion or find and continue the previous one. R7000 router with windows 11 I have two networks -2....
- Jun 17, 2022
required_alias wrote:
version V1.0.11.126_10.2.112. No notice of more recent updates:
Modem - Arris CMB20A
APs What is the brand and model# of these APs? Turn OFF these APs for now and just work with the router for now.
Set Network50 to Channel 40.
Network24 is set to channel 10< this should be channels 1, 6 or 11.
Neighbor wifi that show on Android setings is 4.
Maybe I'm reading your security suggestion wrong. I don't have a choice of "WPA2/AES Only."Your last suggestion > "Try enabling Beamforming, WMM and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings" I'm completely lost. <Are these options seen at this location?
required_alias
Jun 17, 2022Guide
APs
required_alias
Jun 17, 2022Guide
Forgot to mention. I have two APs cabled to the router.
