ramhad3
Mar 13, 2017Aspirant
lost connection to cameras remotely
I have been using. http://www.samsungipolis.com/ipolis/ipoipolis.asp for my remote cameras. One day power went out it stopped working remotely. I tried loggin in and found that https://ddns.hanwha-se...
- Mar 16, 2017
Problem solved. Not even sure what I did LOL
Thanks for the replies
Mar 14, 2017Guru - Experienced User
Did you check the UPnP port mapping table in the router? I'm guessing that the DVR system was able to open the port with uPnP, and that your web page issue is about something else.
You could turn off the DVR system, reboot the router, and then try forwarding the port.
If you use port forwarding, then you should reserve the IP address of the DVR system btw.
ramhad3
Mar 14, 2017Aspirant
what and how to find the info for uPnP
im lost
