ramhad3
Mar 13, 2017Aspirant
lost connection to cameras remotely
I have been using. http://www.samsungipolis.com/ipolis/ipoipolis.asp for my remote cameras. One day power went out it stopped working remotely. I tried loggin in and found that https://ddns.hanwha-se...
- Mar 16, 2017
Problem solved. Not even sure what I did LOL
Thanks for the replies
Mar 16, 2017Guru - Experienced User
ramhad3 wrote:
Ok I found the UPnP Stuff and it looks like port 80 is assigned to something else? How did that happen? Cameras were fine for years. Im so confused lol
The other device asked your router to open the port. The upnp map will tell you that device's IP address. You can then find the device that is currently using that address.
Another option is to turn off upnp and reboot the router. Programs that are relying on upnp to open ports will fail, and as you come across them you can add new port forwarding for them.
ramhad3
Mar 16, 2017Aspirant
