ogeff
Jan 08, 2022Aspirant
Lost connection to R6800 AC1900
Dear all, I have a problem with my R6800 AC1900, and the different connexion on it. My computers and other device keep loosing internet from it, the device disappear, then comes again only if I ...
- Jan 13, 2022
So I followed your step for the reboot of the Router and AP but I had did it already, so no change in my connection.
When I say the 5Ghz Reset is:
before I click on it, it says that he has internet, once I click on it, for a second it says that he doesn't have internet, then it doesn't appear in my available wifi for about 20 sec (as well as the 2.4Ghz) and when it reappears it gets connected, I have internet for a few second then, losing connection to it and not appearing anymore.
BUT (and that's a huge update) I think I'm looking in the wrong direction, from what I saw on another forum it seems that the problem is coming from windows.
I launched a "Netsh wlan show wlanreport" command and so it seems that my USB for wifi adapter seems to fail to connect to it.
So I'm gonna work on this now.
Jan 10, 2022Guru - Experienced User
Your ISP modem have a built in router by chance?
Do both wired and wireless loose connection?
Does any of the NG routers LED change to amber or red when this happens?
ogeff
Jan 10, 2022Aspirant
Yep, the freebox got one.
Only the wireless connection.
Unfortunately I'm not close to the Netgear when it happens (different floor), but I can check this tomorrow
