Ekpuz
Jun 06, 2022Aspirant
Lost google home network after changes to R7000
I used to have my R7000 (firmware version v1.0.11.126) configured as a subnet (maybe not the precise term) off of a Ziply/Frontier router. Unexpectedly, Ziply came and changed the router and messed ...
Jun 06, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/24104/How-do-I-change-my-Nighthawk-router-to-AP-mode-after-I-ve-already-run-setup
Try option #2 first on the R7000
Ekpuz
Thanks so much for the quick reply. The Ziply modem is an (Arris?) NVG578LX. The situation is that the Ziply modem is in a main house, while the NG one is in a separate dwelling. We are an extended family situation, so keeping the two networks separate isn't super critical, but I think would be nice just to minimize the number of devices one house or the other would have to be concerned about when debugging connectivity issues. The two buildings are too far apart to share a wireless network, and again, it is desirable to keep them relatively independent of each other. So, I want to keep the wireless and wired connections at both locations (on both the Ziply and the NG routers). Right now it is mostly working with the NG configured as an access point with its wifi networks having different SSID than the Ziply. The primary downsides of this current configuration is that the Google home devices no longer work properly, and the minor downside is that we are no longer on separate networks so the main house can see the auxiliary house, and vice versa. I haven't tried going through the setup process for the lightbulbs and Google Home speakers, so that may be a viable option. I did read something somewhere that mentioned making sure that a setting on the router allowed devices connected to see each other, but I didn't see that on the NG router (when it is in AP mode some settings are inaccessible so maybe that is why). I'm motivated to find an option different from what I have now because I liked what I did before, but just can't remember the right words to find the instructions for what I did. I think it involved setting up a subnet with the appropriate mask, probably some setting having to do with DHCP, and maybe some port forwarding. It may have also involved doing something like assigning the NG router a fixed IP address. Again, I'm really not very knowledgeable about this stuff and I could be misremembering or misusing some words. I just know I found very easy to follow instructions that enabled me to do what I did without too much trouble.
What I did before was attractive because it ended up doing what I wanted, but if there is a relatively inexpensive piece of hardware that would facilitate accomplishing what I want, without too much trouble, I'd be open to learning about that. Would a simple switch a couple of ports let me create the separate network? If I could use something like that, then maybe putting the NG router as one of the outputs from the switch would be easier than trying to brute force the NG router to work differently than it is primarily designed to do. The switch idea led me to doing a quick search and finding this: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Configure-R7000-as-a-switch/td-p/1470186. Maybe that is what I did before? If that is a viable option, then I just need to find more detailed instructions. However, if a $20 switch would be more plug and play, then that may make more sense.
- FURRYe38Jun 06, 2022Guru - Experienced User
You might try option #3 then. Would be easiest to setup and configure.
