Steve_K
Jul 13, 2021Follower
Lost Internet Access Between CM700 and R6700v3
Hi. I had a setup that mysteriously stopped working today. Despite being able to connect in the past, I was suddenly unable to connect via IP address to my cable modem, and at the same time, my router lost the connection to the internet.
My setup is a little different, going back to a previous ISP, but worked fine for a year plus...
My modem is a CM700 with default settings, IP 192.168.100.1
My router is a R6700v3, with a static LAN IP of 10.96.###.###, and my devices have IPs assigned by the router.
The router Internet settings were 'Get from ISP'. Previously, I had no problems access the modem by its IP address. Today, the router lost internet access, and I was unable to access the modem via the router.
After it stopped working, I set a static IP on my laptop and can connect to the modem and access the internet. I can set a static Internet IP on the router and can then access the modem, but the Internet still doesn't work.
If anyone has advice, I'd gladly take some...
No RepliesBe the first to reply
