Lostintech
May 27, 2021Follower
Lost Networks
So I've had this R6400v2 for about a year and it's worked flawlessly. This afternoon when I got home, it was working normal. About 2 hours later I had no internet. When searching my networks, my m...
May 28, 2021Guru - Experienced User
What modem/gateway is it connected to?
What firmware is on the router?
When you factory reset, did you push and hold reset for 7-15 seconds while its powered on?
You're able to access the router through the browser, it just won't setup the internet connection?
