SCHNEB
Jul 31, 2022Aspirant
Lost T_Drive
Something is extremely wrong with the NETGEAR Web site. I was trying to edit the T_Drive partition, but choosing "Edit" did not allow me to edit any of the boxes. I was using the latest Chrome, but n...
Jul 31, 2022Guru - Experienced User
Not much to go on.
There a NG product your referring too?
SCHNEB
I have a Nighthawk R8300, but it is working just fine. The problem is the Web site I posted. The Edit button does not allow me to make any changes. I can't repair the T_Drive drive.
- michaelkenwardAug 01, 2022Guru - Experienced User
The "website" you refer to is no such thing. It is the browser graphical user interface (GUI) for your router. That's the place where you get in to manage the router. Netgear just uses html as a way of showing the information.
In this case it seems that you are trying to work with ReadySHARE.
Can you see the T_Drive on your network?
Point Microsoft explorer at
\\readyshare\
You'll have to dig bit deeper and tell us more before anyone can help.
Tell us what you are doing and where things go wrong.
A first move would be to check that the USB drive still plays nice with your PC.
- SCHNEBAug 04, 2022Aspirant
OK, I removed my USB drive and reformatted it, starting from scratch. I hooked it back up, gave it a little time, and eventually it showed up as before. I guess the "Edit" button only seems to allow deletion of a particular volume, which is confusing on the GUI. To me, it seems like the Edit Button should be allowing the ability to change the name or the access, but it does not.
Thanks for the help.
