scott_best
Jun 17, 2020Aspirant
Lost WiFi on Nighthawk X10 R9000 after changing Spectrum cable modem.
I had to upgrade my Spectrum cable modem today from 100 MBS to 400 MBS to permit remote work on a CAE server to be efficient. I had to replace the cable modem to make this happen, and my Internet co...
- Jun 18, 2020
I think I found the WiFi ON/Off button on the top right side of the R9000, which is not obvious since it appears to be flush light, but it is a button. I was able to depress the button, which enabled the 2.4 and 5.8 GHz wireless systems. Thanks for the suggestion, which prevented me from have to rebuild the wirless systems this weekend.
Netgear needs better documentation with photos to assist with finding this button.
Thanks again,
Scott
michaelkenward
Jun 18, 2020Guru - Experienced User
Did that involve a new modem? Or some tweaks to settings?
Replacing a modem can change your network in ways that wreck the settings on your router, which is remembering how it worked with the older modem.
If the suggestions from plemans don't work, you may have to reset the R9000 and set it up from scratch.
scott_best
Jun 18, 2020Aspirant
Yes, I was required to replace my old Spectrum 100 MBS modem with a new 400 MBS modem yesterday, which casued this problem to happen. If I have to press the RESET button on the bottom of the router, then I will have to wait to rebuild the router settings over the weekend since I do to not want to interrupt my work today or tomorrow.
Thanks,
Scott
