markyac
May 19, 2020Aspirant
Lost WIFI on R6900v2
Hi all, WIFI was working fine and in the last hour or so, just stopped. Model R6900v2. I have powered OFF/ON both Modem and Router several times. I can log in via routerlogin.net if that help...
- May 20, 2020
markyac wrote:
You seem nice.
Sorry about that.
When you did the power cycling did you do it in the right order?
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Check the section that deals with troubleshooting with the LEDs.
antinode
May 19, 2020Guru
> 2.4 - OFF
> 5 - OFF
Might be a hint.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
LED descriptions and "Troubleshoot". Pay particular attention to the
"WiFi On/Off button with LED". Did you press it? (Further reading
might be helpful, too.)
- markyacMay 20, 2020Aspirant
You seem nice.
- michaelkenwardMay 20, 2020Guru - Experienced User
markyac wrote:
You seem nice.
Sorry about that.
Support | NETGEAR
Check the section that deals with troubleshooting with the LEDs.- antinodeMay 20, 2020Guru
> Sorry about that.
About what, exactly are you "Sorry"?
> Visit http://netgear.com/support , put in your model number, [...]
> If you visit the support pages: [...]
Oh, I see. It's much more charming when _you_ tell someone to read
the documentation than when I do it.
