markyac
May 19, 2020Aspirant
Lost WIFI on R6900v2
Hi all, WIFI was working fine and in the last hour or so, just stopped. Model R6900v2. I have powered OFF/ON both Modem and Router several times. I can log in via routerlogin.net if that help...
- May 20, 2020
markyac wrote:
You seem nice.
Sorry about that.
When you did the power cycling did you do it in the right order?
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
Check the section that deals with troubleshooting with the LEDs.
markyac
May 20, 2020Aspirant
You seem nice.
michaelkenward
May 20, 2020Guru - Experienced User
markyac wrote:
You seem nice.
Sorry about that.
Support | NETGEAR
- antinodeMay 20, 2020Guru
> Sorry about that.
About what, exactly are you "Sorry"?
> Visit http://netgear.com/support , put in your model number, [...]
> If you visit the support pages: [...]
Oh, I see. It's much more charming when _you_ tell someone to read
the documentation than when I do it. - markyacMay 21, 2020Aspirant
Thanks.
- michaelkenwardMay 21, 2020Guru - Experienced User
