cpwlew
Apr 21, 2021Aspirant
Lousy product
Had a Sprectum modem (and router) combined. Wanted to do more on the internet so I got a new modem from Sprectum in January of 2021. Needed a router so I acquired a Nighthawk router - X6S. The rou...
michaelkenward
Apr 22, 2021Guru - Experienced User
plemans wrote:
1. many people google for supports number. If you did this, you more than likely didn't get netgear as there's a lot of scam sites out there.
Netgear isn't the only victim of this sort of scam.
So, anyone buying a different brand should avoid making the same mistake.
It is a bit like the warnings from your bank. Don't trust anything you find on the Internet. Engage brain before dialling.
