Vice94
Feb 13, 2023Aspirant
Low Ethernet Speeds - R8000 Nighthawk
About three weeks ago Comcast upgraded our internet from 400Mbps to 800Mbps. I was still getting back results from speed tests of about 250Mbps, which is when I started to look into my issue. I tried...
Feb 13, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
- Vice94Feb 13, 2023Aspirant
I submitted a reply but it's just gone for some reason.
V1.0.4.84_10.1.84
I saw another thread about this firmware being buggy and people complaining about it almost a year ago with no fix in sight.
Armor, Smart Parental Controls or Circle, Traffic Meter.Already disabled.
Yes.
- FURRYe38Feb 14, 2023Guru - Experienced User
What CAT# cabling are you using between the modem and router and router and your PC?
Have you tired a different PC or laptop ethernet connected to the router to compare results?
What speed test app are you using? Ooklas installable speed test app is recommended.
What speed tier do you pay for from the ISP? They recently changed speed tiers as of last year. Reporting 800Mpbs and 1.2Gb now.
Please post a copy and paste of the modems connection status and event log page.
