Vice94
Feb 13, 2023Aspirant
Low Ethernet Speeds - R8000 Nighthawk
About three weeks ago Comcast upgraded our internet from 400Mbps to 800Mbps. I was still getting back results from speed tests of about 250Mbps, which is when I started to look into my issue. I tried...
Vice94
I submitted a reply but it's just gone for some reason.
V1.0.4.84_10.1.84
I saw another thread about this firmware being buggy and people complaining about it almost a year ago with no fix in sight.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Already disabled.
Yes.
Feb 14, 2023Guru - Experienced User
What CAT# cabling are you using between the modem and router and router and your PC?
Have you tired a different PC or laptop ethernet connected to the router to compare results?
What speed test app are you using? Ooklas installable speed test app is recommended.
What speed tier do you pay for from the ISP? They recently changed speed tiers as of last year. Reporting 800Mpbs and 1.2Gb now.
Please post a copy and paste of the modems connection status and event log page.
