johnny51380
Sep 01, 2017Aspirant
low speed and coverage
i installed a r8000 and basically used the default settings. my house is an L shape and about 2200 sq ft and this router doesnt cover my whole house. the connection seems slow unless im in the same r...
- Sep 28, 2017
Hi johnny51380,
Try to remove the genie software and changed channel for 2.4Ghz and 5Ghz.
johnny51380
Sep 04, 2017Aspirant
firmware 1.03.54
through spectrum i am suppose to get 60mps. when i do a independent test i get 70mps. when i do the test through netgear genie i get like 30mps.
when i go to the furthest spot in the house i still have wifi bars and when i connect to either 2.4 or 5ghz it says signal is fair and about 65mps connection speed but when i try to do anything online its pretty much a lost cause and it disconnects wifi and tries to connect to a different one.
JamesGL
Sep 13, 2017NETGEAR Employee Retired
Hi johnny51380,
What did you use to test the speed when you get 70Mbps? Is it connected to the router?
- johnny51380Sep 16, 2017Aspirant
i used a desktop computer directly wired to the router. i used an online speed test.
- JamesGLSep 28, 2017NETGEAR Employee Retired
Hi johnny51380,
- JamesGLOct 02, 2017NETGEAR Employee Retired
Hi johnny51380,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
