Jinmzhao
Oct 09, 2021Follower
M4300 Bootup Failure
My M4300 8x8F can't boot up, and the power LED is solid yellow. the fan works fine and rear panel has green led with PSU. here is the informaiton from console. but i can't type anything to this wind...
michaelkenward
Oct 10, 2021Guru - Experienced User
This place is for Nighthawk WiFi Routers. The M4300 isn't one of those.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Discuss Ethernet Switches Plus and Pro Managed
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
