edukehtoer
Jun 10, 2021Aspirant
M60 Connection Weakness
I have a NightHawk mesh 6 system newly installed. (I cannot find technical specifications on the model list that match.) The second satellite closest to the garage has a very weak signal on my s...
edukehtoer
Jun 11, 2021Aspirant
Under technical specifications the box says AX1800 router and satellites. That doesn't seem to be on the list either. Under "box contents it says One Mesh Wi-Fi 6 Router (MR 60) the label that has the serial number the TA and the Mac doesn't have any kind of number that looks like a model designation.
I'll look up the paperwork but I was hoping that somebody just might be able to tell me why I'm not getting a good signal in the garage other than the Faraday effect. Unlike some of you who understand these machines better, there are those of us who will never be able to decipher complex technical instructions. Although much of it is easy some of it might as well be Greek.
michaelkenward
Jun 11, 2021Guru - Experienced User
edukehtoer wrote:
Under technical specifications the box says AX1800 router and satellites. That doesn't seem to be on the list either. Under "box contents and says One Mesh Wi-Fi 6 router MR 60" the label that has the serial number the TA and the Mac doesn't have any kind of number that looks like it's a model.
Try the label on the thing. Something like this:
My guess is the MK62 bundle, MR60 plus MS60. Your subject says M60.
Best discussed here:
- edukehtoerJun 18, 2021Aspirant
Thank you Michael I will look at that article. This is the label on the router. Both satellites have labels exactly like this one
- michaelkenwardJun 19, 2021Guru - Experienced User
It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
You can attach images to messages without any delay.
