sgmstr
Jan 28, 2022Aspirant
Mac Devices Connection Issues
R6400V2 with Firmware V1.0.4.122_10.0.95. Mac devices not connecting to Internet (only connect to Wifi Router). Non-Mac devices connect to Internet awith no problem. It happens randomly and re-...
Jan 28, 2022Guru - Experienced User
Do you have IPv6 enabled?
What modem/gateway is the router connected to?
Did you try downgrading?
or even a factory reset/reinstall?
- sgmstrJan 28, 2022Aspirant
IPv6 enabled.
Arris Surfboard SB6190 Modem
Trying to avoid downgrading as it could cause issues (leaving as a last resort)
Performed factory reset.
