TroyK's avatar
TroyK
Mac OS - R7000 Nighthawk - System/DNS Server does not 'hold' the router address
Mac OS 12.4
I did my first post to this forum earlier today and got such excellent help. thanx
Thought I would throw up another that has been bothering me for awhile.
Our service providers DNS Servers are unreliable.
A very knowledgeable friend of mine suggested I use googles DNS numbers of:
8.8.8.8 and
8.8.4.4
I did a little research and it seems this is used by numerous folks.
So in my R7000 Nighthawk router with V1.0.11.134_10.2.119 software.
Under basic/internet I have designated those DNS numbers to use. (see screenshot)
In my system prefs/network/advanced/DNS/DNS Servers - when I delete the provider, provided DNS numbers, I see my router ip show us as it should, 10.0.2.1. I then click OK, But when I click apply, 9 out of 10 times, the router IP disappears, and the provider provided numbers re-appear.
- I did a bit of learning about clearing the DNS cache, and I have done that numerous times, usually to no avail.
- When the router number does hold, and we're using the google dns numbers, our internet is very stable. - When I have to use the provider DNS, it can be unstable.
All this just to ask if anyone has any experience/feedback about this.
BTW- I am not the strongest computer guy, but I know enough to get in trouble. 😃
I appreciate the forum, thanx
Troy
  • The devices will not show the routers DNS settings.
    But the router will pass the information via the router defined DNS.
    I have all my devices setup with Google DNS and the router DNS set too.
  • FURRYe38's avatar
    Do you mean inputting the DNS on the R7000 web page change back from Google DNS back to ISP DNS?
    • TroyK's avatar
      TroyK
      No, the router is not assigning the google DNS to any of the connected devices.
