DieMatrix
Nov 23, 2021Aspirant
Mac Problem - Radyshare Verbindung will nach Deinstallation hergestellt werden
Hallo zusammen, ich hatte die Software NETGEAR Genie auf meinem iMac und hatte hier ein Netzlaufwerk verbunden. Nun habe ich die Software deinstalliert. Leider kommt immer die Meldung "Beim Verbind...
Nov 23, 2021Guru - Experienced User
Englisch Bitte
I would post about this over in the NG Genie App forum for help and information:
https://community.netgear.com/t5/Genie/bd-p/home-genie
Thank you
- DieMatrixNov 23, 2021Aspirant
I had NETGEAR Genie software on my iMac and mapped a network drive here.
Now I have uninstalled the software. Unfortunately, the message "Radyshare encountered an error while connecting to the servcer" always appears.
The popup comes directly when the MAC is started.
It also happens when I have the program open and click on "Preferences" at the top.
There is no longer any software on the Mac.
Where can I delete the entry so that the Mac doesn't always want to connect to Readyshare.- FURRYe38Nov 23, 2021Guru - Experienced User
I beleive if you drill down to where the Preferences folder is kept on OSX, you can manually remove the lingering NGicon/app seen in preferences which may remove the entry. I would do a search on line to see where the OSX preferences folder is and see if there is a entery for any NG items listed there.
